how to access my 3cx phones system out the office
Discussion in '3CX Phone System - General' started by jerryl, Aug 31, 2011.
  1. jerryl
    Aug 31, 2011
    7
    I'm just wondering if i can remote my 3cx phone system server in the office? Is 3cx phone system has this capability? I'm just a new user of this system. If it can be access outside the office, what would i set, would should i do. Thanks more power and God bless..
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
  3. willow
    willow Member
    Mar 1, 2011
    471
    the 3cx uses port 5000 for all new implementations. so if you port forward 5000 to the 3cx server on your router then you can access programming remotely. also you can use vpn, vnc or a host of other applications to get remote access to ther server.
