How to Activate RingGroup in Call Control API
Discussion in 'CRM / Helpdesk / App Integration' started by VITS 3CX, Mar 16, 2018.
  1. VITS 3CX
    Mar 12, 2018
    17
    How to Activate RingGroup by *9 in Call Control API
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,673
    131
    Hello @VITS 3CX,
    That's the dial code to start an intercom call. For example, you dial *9100 if you want to make an intercom call to extension 100. If you need to make a call to that number from the 3CX Call Control API, you just use the MakeCall method and set one of the endpoints to "*9100".
    Kind regards.
  3. VITS 3CX
    Mar 12, 2018
    17
    Thanks for valuable response.
  4. edossantos
    Jun 27, 2007
    1,673
    131
    Please note that the dial code is disabled by default. You might need to go to your 3CX Console > Settings > Dial Codes > and set the value *9 (or any other) for Paging.
  5. VITS 3CX
    Mar 12, 2018
    17
    How to play voice on given extension during call in Call Control API
  6. edossantos
    Jun 27, 2007
    1,673
    131
  7. VITS 3CX
    Mar 12, 2018
    17
    sir how to use of Announcement class in call control api and how to play these Announcement in given extension
  8. edossantos
    Jun 27, 2007
    1,673
    131
    That's not the way to go. Please use the suggested approach I've explained in the other thread.
