How to activate the "Do not disturb" status of another extension ?
Discussion in '3CX Phone System - General' started by cyclone76, Mar 12, 2017.
  1. cyclone76
    Mar 3, 2017
    44
    From my extension, is it possible to activate the "Do not disturb" status of another extension (dialing a code like * 60 and * 61 on my own extension)?
    Thank you
    10,586
    252
    Not that I'm aware of. If someone doesn't wish to be disturbed, then you have to assume that they are close to the phone, which means that they would be capable of activating the feature themselves, if desired.
  3. cyclone76
    Mar 3, 2017
    44
    I regret there is no option to allowed or not that. It would be practical for small companies or the secretary is not always at his office. This would make it possible to send calls from his post to another without moving to the secretariat.
  4. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    107
    39
    Easily done in the management console (each extension can have credentials, and the ability to only edit own extension) Another possibility is to have multiple extensions provisioned in the smart phone or Windows app, it's pretty easy to switch between accounts then use the dial code.
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi cyclone76,
    Also you can do that through voicemail if you know the extension pin number (voicemail pass). You can call to voicemail (999) then press # and then the system will ask you to type the extension number and password. Next, dial “9” for options and then you can dial the option “1” to allows you to change the extension profile status. May I refer you on this link https://www.3cx.com/blog/voip-howto/managing-voicemail/
