How to add 0 in DID when received inbound call
Discussion in '3CX Phone System - General' started by bluetel2, Jul 16, 2009.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    anyone can said me how we can add 0 when we received inbound call. for exemple when have an external number like 06 84 xx xx xx, but when softphone or physical phone received call, it's write 6 84 xx xx xx.
    and for 3cx assistant don't resolve name, because it's write with 0.
    we have patton 4638, and 3cx v7.1.711
    tks
  2. wzaatar
    Aug 1, 2007
    90
    I asked the exact same question a year ago, of the 3cx guys said that they didn't have it, but that was in v5 or 6 if my memory serves me well. Check this post: http://www.3cx.com/forums/prepending-digits-on-callerid-8598.html
    I did check on v7, it's still not there. Maybe adding it to the wishlist! :D
    Although I did find this feature in another free SoftPBX by NCH which allows you to add whatever you want at the beginning of the number.
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    thank for your answer.
    we wait an answer of admin, or developper to see if we can do anything.
    thaks ;)
  4. wzaatar
    Aug 1, 2007
    90
    De rien, cher collègue.
    Bonne journée,
    W.
  5. mbaltus
    Dec 12, 2008
    66
    I had similar problems with my Patton 4960, but this is just a setting in the Patton that needed changing. After that, the Patton adds the prefix-0 thus reporting the correct number and the problem was gone.
  6. wzaatar
    Aug 1, 2007
    90
    That fixes it at a gateway's end... And only if the gateway supports it. How about if you have a VoIP provider? :)
    It would make more sense to see this feature in 3CX.
    Cheers,
    W.
  7. mbaltus
    Dec 12, 2008
    66
    Very true, if it wasn't for a glitch in the E.164 representation by the Pattons, If I remember correctly (and this then applies to my SmartNode 4960).
    Furthermore it solves (or actually works around) the problem TS currently has
  8. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    and for patton 4638 there is solution ? maybe in next firmware ?
  9. mbaltus
    Dec 12, 2008
    66
    On the SmartNode 4960 I had to set-up the options National Prefix and International Prefix (with 0 and 00 respectively) on the Configuration tab of the Telephone/Call-router options.
    Perhaps a good idea to include them in the SmartNode config template included with 3CX?
    The v5.3 commands in the config file are (i.e. the relevant part of the config file):
    Code:
    context cs switch
      digit-collection terminating-char # append-terminating-char set-address-complete-indication
      national-prefix 0
      international-prefix 00
  10. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    Ok ,thks mbaltus, i will look this monday for 4638.
