How to add call costs
Discussion in '3CX Phone System - General' started by dimitris104, Sep 15, 2016.
  1. dimitris104
    Sep 15, 2016
    Hi, i am using 3cx system and our telephony provider has given us a list with the costs of the calls containing national/international/mobile costs for every existing country. My problem is that i dont know exaclty how to add these prices in my 3cx system. I am using 3cx v14 and the procedure i am following is Server manager>CDR>Enable
    after this at the same section i click "Call costs" at the top and i add the cost i am given, for example calls to Greek mobiles cost 0.05€ per minute so i create a new country name GreekMobile and add as prefix 69 (since all greek mobile numbers begin with 69) and when i generate the report to me email i dont see any changes to the costs and gets the ByDefault 3cx value Rate=1.0
    i tried even adding 3069 (30 is the country code for greece) and again i get the same values as before.
    So how can i add the call costs in my 3CX system and see the actual cost of my calls via Call Reports??
    Thanks, Jim :D
  2. dimitris104
    Sep 15, 2016
    so anybody used this 'call cost' feature?
  3. hogan71088
    Nov 30, 2015
    62
    bump for answer to this.
  4. Steven Peters
    Mar 23, 2017
    another bump, I also have a list of call rates (per minute) that I'd like to enter into our company 3CX version 15.
  5. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Steven Peters,
    I'd like to ask, the prefix you use in the CDR, what form is it in, and is it the same with your outbound rule prefix?
  6. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    The prefix needs to match the outbound call prefix, otherwise it won't price it properly. Other than that they to see new calls after the cost was added. Since also calls have already been recorded on the CDR it should show the old pricing.
  7. datamerge
    datamerge New Member
    Nov 19, 2014
    181
    25
    Is there a way to enter an untimed rate?
