How to amend dial plan to 3CX?
pacpac
Forum User
Hi, I am currently using this dial plan:
(00x.|<0:0044>[1-357-9]xxxxxxxx|<0:0044>[1-357-9]xxxxxxxxxS0|*xx|[1-9]xxS0)
How do I amend so I would be able to dial, *777, *1, etc.? Thanks.
What is your device -- the dial plan looks like Cisco/Linksys SPA.
In this case you simply add *1 and *777 to dial plan. Note you have already *xx, which are internal codes for SPA devices.
You must change the existing dialplan
to
(00x.|<0:0044>[1-357-9]xxxxxxxx|<0:0044>[1-357-9]xxxxxxxxxS0|*777|*1|[1-9]xxS0)
You may need to modify the internal SPA codes if 3CX dialplan conflicts with the device (from device menu).
Regards
Thanks, just tried to insert *777 and it works fine. Do I need to insert every *(then code) for each code I want to use in 3CX, or is it a generic string I can set applicable for all * codes?
Have a look at this link.
http://www.scribd.com/doc/238209/LinksysSipura-Dial-Plan-tutorial
You can use an "x" to mean any digit, or you can specify a single digit (that is allowed), or a range of digits.
So |*xxx| would allow any 3 digit star code, or |*7xx| would allow only codes beginning with 7.
Codes are "match attempted" from left to right.
Thanks, this dial plan works perfectly:
(00x.|<0:0044>[1-357-9]xxxxxxxx|<0:0044>[1-357-9]xxxxxxxxxS0|*xxx|*xx|*x|[1-9]xxS0)
Getting Started - Admin
deanhbs
Get 3CX - Absolutely Free!
3CX
