How to assign a VOIP account to a line on 3CXphone
Discussion in 'Windows' started by dx7, Dec 2, 2010.
  1. dx7
    dx7
    Oct 7, 2010
    25
    3cxphone for Windows has 5 lines. I have added credentials for 2 voip accounts. I can't see where I can assign an account to a line.
    Thx
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, if you go to Ports / Trunk Status – select the VoIP Provider account
    You will see a section of the screen labelled “Office Hours”
    In this section, you can define where the calls will route to
    “Connect to Extension, Connect to Queue / Ring Group etc
  3. dx7
    dx7
    Oct 7, 2010
    25
    Thank you David, that info accurately describe the process to connect the 3CXPhone to the PBX. I however meant to refer to the stand alone 3CXPhone, not to the PBX. The stand alone 3CX phone allows you to provision several accounts and it has 5 lines, which sort of suggests that you should be able to set up one voip account per line. I tried with 2 different accounts right in the softphone but was unable to assign a specific voip account to any specific line. I'd like to know how to achieve that.
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    You are confusing those keys. They should properly be called "Call Appearance" keys. They are not used to specify specific trunks.
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    There is no assignment between accounts and lines. This is for flexibility purposes. Therefore, you may simultaneously have 20 active accounts and phone's five lines. By repeatedly clicking any line you may choose any of those 30 accounts. Also, an incoming call from any account will be directed to the first available line.
