How to block IVR dial to extension
Discussion in '3CX Phone System - General' started by Cecil Law, Mar 2, 2017.
  1. Cecil Law
    Mar 2, 2017
    Dear All,
    I am 3CX newbie and I testing 3CX version 15 IVR function.
    I tested incoming call can dial extension in IVR. How can I block this function.
    Because I don't want incoming call can direct call my Boss.
    #1 Cecil Law, Mar 2, 2017
    10,586
    252
  3. TC-MagazineK12
    Jul 22, 2017
    7
    7
    The IVRDONOTCALL parameter does not work with V15+. I had issues with people having the ability to call in to paging groups or extensions such as classrooms... Not cool. Additionally 3CX wanted more money just for tech support. But a little detective work and recognition of regular expressions yielded a fix/solution.
    Ready for something that does fix this issue? IVR_DIRECT_DIALING_GRAMMAR is simply a regular expression. Adjust that parameter to suit your needs and restart the services, or easier just restart the server.
    As an example the below regular expression, aka what is set for IVR_DIRECT_DIALING_GRAMMAR, disables the ability to dial extensions 2400 and 2500 while still recognizing four digit extensions:
    ((?!2400|2500)[0-9]{4})
    Another example if you want to disable all direct dialing all together use the below to recognize only one digit between zero and nine :
    [0-9]{1}
    #3 TC-MagazineK12, Jul 22, 2017
    vizualpro, cobaltit and teldata1 like this.
  4. ivank
    3CX Support
    Jan 4, 2017
    54
    5
    IVR uses ECMAScript regular expression syntax.
  5. TC-MagazineK12
    Jul 22, 2017
    7
    7
    Thank you for that tidbit :) Any chance 3CX wants to remove the deprecated parameters V15+ and update the website documentation that's from 2010? :)
    vizualpro likes this.
