How to build a STUN Server
Discussion in '3CX Phone System - General' started by cjammer, Jan 10, 2007.
  1. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    Can someone tell me how to build/make/download a STUN Server?
    Cjammer
  2. Watashi_FR
    Dec 5, 2006
    63
    There are several options available, both for Windows and *nix. Google for "stun server download".
  3. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    I found a couple through the search, downloaded them from sourceforge and it shows they ARE Beta. I would not depend on them yet for stability.
    Anyone found a good one?
    Cjammer
