how to call internal extension while out of the office
Discussion in '3CX Phone System - General' started by lebric, Jan 27, 2013.
  1. lebric
    Jan 21, 2013
    I'm very new to this so my apologies.
    I would like to know if it is possible for an external extension configured (out of the office) to be able to make regular outbound calls and dial internal office extensions ? the internal office extension are able to dial the external extension but not vice versa. i ve been struggling on this for 2 days now any help would be extremely appreciate.
    Eric
    Super Junior
    11,101
    329
    The external extension should be able to place both internal and external calls (outbound rules allowing).
    The extension can be called, so it is obviously registering. How have you datafilled the 3CX server in the remote? Are you using an IP, or using a Domain name (DynDNS type service)?
    If it is the latter, then you must put that name in as the Domain Name in 3CX. The 3CX logs will show the call being rejected otherwise.
    If you continue to have issues post the 3Cx log of an incoming call attempt.
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    This 'how-to' is always a great place to start ...
    http://www.3cx.com/blog/voip-howto/remote-extensions/
    Your remote extensions should be making and taking calls in the same way that your on-site extensions are. If they are not, it could be that you need to look at what ports are open [http://www.3cx.com/blog/docs/ports-used/] on your main site's router - and you also need to make sure that STUN settings are enabled (and the chosen STUN server is able to be ping'ed) on your remote phones.
    Best regards
