How to change 5060 port to another port in 3CX Linux?
Discussion in '3CX Phone System - General' started by Elvin Mammadov, Mar 11, 2017.
  1. Elvin Mammadov
    Feb 3, 2017
    42
    I installed 3CX LInux. In our country 5060 SIP port is always blocked by ISPs. So I changed 5060 port to another port in 3CX settings, but since I am not good at Linux, I don't know how to change 5060 port to another port in Linux. Could you please help on this matter? Thanks in advance.
  2. Ben Lockwood
    Mar 10, 2017
    8
    Hi Elvin
    Assuming you have changed the port in the Settings_Network Settings_Port section, then I would also change the port in the SIP trunk and handset provisioning sections as well before testing.
    Don't forget to restart alls services once you have done this as well.
    Good luck
    Ben
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,822
    564
    You will also have to change your IP tables so that the new port is allowed
