how to change default Music On Hold?
Discussion in '3CX Phone System - General' started by AlexT, Jun 1, 2015.
  1. AlexT
    Oct 12, 2013
    How to change default Music On Hold when the call comes from the city?
    It plays something that is completely different when I enter the extension for it to play!!!
    This is not work:
    * General>Music On Hold (onhold is located in: C:\ProgramData\3CX\Data\Ivr\Prompts)
    * QUEUE (To change the music while a customer is in a QUEUE can be set on the queues under "Other Options)
    * Renaming onhold.wav (onhold is located in: C:\ProgramData\3CX\Data\Ivr\Prompts)
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi Alex,
    Can you elaborate further what do you mean by when a call is coming from the city ? A different message should be played when the call is coming from a specific caller ID ? i.e. The numbers for the city that you are located are starting 1234, thus when a call is coming from 1234567 a different music on hold should be played ? With regards to the queues prompts please note that you can add a separate file.
    Regards
