How to change log file address...
Discussion in '3CX Phone System - General' started by rkm7232, Jul 28, 2014.
  1. rkm7232
    Jul 28, 2014
    6
    Hi, sorry for my poor english...
    I want to change the log file 'CallHistoryService.log' to another location for remote access..
    for that, I edit the '3CXLogger.ini' , [CallHistoryService\Logger\Outputs\LogFile] section.
    and then restart all services.
    but anything doesn't change and log save in "CallHistoryService.log" yet.
    is there any way to change the log file address?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    I'm afraid these settings are now obsolete, it will always write in default folder.
    If you need, you can make a batch and run it through scheduled task every 1 minute to duplicate the log in another location.
  3. rkm7232
    Jul 28, 2014
    6
    Thanks for your response,
    I'm a programmer n I use windows logs because I need the last event in 3CX logs and now I can retrieve it,
    This approach can help others later...
