How to change or remove "Please hold while I transfer your"
Discussion in '3CX Phone System - General' started by sigrid, Jan 19, 2010.
  1. sigrid
    Jan 19, 2010
    I am completely new with 3CX but I have set it up correctly and it works just great!
    But I come from Norway, and therefore there will be a little wrong that the female voice says "Please hold while I transfer your call" is played when all else is recorded in Norwegian. Is there a way I can change it into Norwegian and record itself, or possibly remove it?
    I know that in certain states in U.S requires that this being said, but it is nescessary as a law in my country.
    Sorry for my bad english and thx for your help :)
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    In the settings section it will show you the filename for each message. You can create a new wav file and overwrite the existing one.
