how to change packet time ms
Discussion in 'Windows' started by smz.bukhari, Jun 9, 2012.
  1. smz.bukhari
    Jun 9, 2012
    hi there
    i m using 3cx but the internet speed is not good so bad sound quality tough skype works
    i want to know that how can i change packet time
    10ms 20ms etc
    11,116
    329
    I suspect that if this were available, it would have to be a "per VoIP trunk" feature, and as such is probably not an option. You might be better off trying to use a codec requiring less bandwidth, if possible.
    The 3CX preferred RTP packet size is 0.020. (recommended setting on devices)
