How to change ptime on 3CX Server
Discussion in '3CX Phone System - General' started by shadow77, Feb 5, 2008.
  1. shadow77
    Jan 25, 2008
    9
    Is it possible to change the value of the ptime on 3CX ???
    :p
  2. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    What is "ptime" and why would you what to change it?
  3. shadow77
    Jan 25, 2008
    9
    Because it's not compatible with my voip provider i assume and i would like to check if the 3CX Server and voip provider is using the same ptime.
    By the way my provider is freephonie
  4. blackburwood
    Feb 18, 2008
    8
    like i am looking for a solution to my trouble of sound during the incoming or outgoing seccession
    i am using freephonie on the 3cx v5 (on the 3cx v2 it s working but only with one account from freephonie, i can t use another account from hte same provider in the same time, 3cx v2 still doen t want to create this account, it s seems stop by 3cx during the configuration mode, and said that i have already a sip provider running freephonie.net
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    ptime is optional parameter and I really cannot understand why this optional parameter can be a subject of "incompatibility"...
    PBX sends outgoing stream using ptime requested by remote party (sure if codec can support it) and handles any packet time for incoming stream.
    Regards
