How to change SMTP port on 3CX
Discussion in '3CX Phone System - General' started by fortytwo, Jan 6, 2016.
  1. fortytwo
    Jan 6, 2016
    7
    I'm trying to configure the SMTP server using gmail but no mails are sent.
    It is possible to modify the SMTP port?
    Thank you! :)
    11,116
    329
    I'm not sure if things have changed (with Google) since this post, but, there are some links listed that might help.
    http://www.3cx.com/forums/post169555.html
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    In your Google Account settings, not GMail settings, under security turn the feature "Allow less secure apps" to on and try again.
  4. fortytwo
    Jan 6, 2016
    7
    I solve the problem by using the Free provider smtp server.
    Thank you guys,
  5. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    You can provide the port number in the mail server config line as seen in the screenshot.
  6. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    Also, 3CX has a guide for using Gmail:
    http://www.3cx.com/blog/docs/gmail-mail-server/
