How to change the "From" email address of the system
Discussion in '3CX Phone System - General' started by Ben C, Apr 18, 2016.
  1. Ben C
    Oct 14, 2014
    71
    I want to change the "From" email address of the system.
    When I get the alerts from 3cx system it says from: 3cx@domail.com. I want to change that to voipSystem@domain.com
    Is it possible?
    I know you set it up when you install 3cx system, but can you change it after?
    Thank you
  2. vanderheyde
    Apr 14, 2016
    You can change this in the settings:
    Settings > Network > Mail server > Reply Address
  3. Ben C
    Oct 14, 2014
    71
    Thank you
    I overlooked it :oops:
