How to change the Management Console to a different Port
noddy184
Hi, currently the default is port 5000 for the web based management console but I need to change it to something else.
How do I change the port?
Assuming you installed 3CX with IIS you can just open IIS and bind another port to the 3CX Website. However you will want to leave port 5000 on there because it is used for more than just web page access. I have noticed the Auto Attendants stop working if you remove it.
If you installed with Abyss im not sure how to do it.
Getting Started - Admin
alkhateeb.itsupport
Get 3CX - Absolutely Free!
3CX
