Solved How to change the profile status using dial codes
Discussion in '3CX Phone System - General' started by aslampa, Dec 10, 2016.
  1. aslampa
    Mar 18, 2016
    44
    I would like to know how to change the profile status using dial codes in V15 Phone system. In older version we have an option is *30 for available,*31 for away etc...This seems to outdated. Please advice
  2. andreasc
    May 19, 2014
    35
    Hi there ,
    Is the same
    Check on your Management Console -> Settings -> Dial Code
    what you set for Change Profile Status option.If *3 is set
    *30 is Available Stratus
    *31 is Away Status .....
  3. aslampa
    Mar 18, 2016
    44
    I did the same but *30 give enable caller ID and *31 Gives Disable Caller ID options
  4. andreasc
    May 19, 2014
    35
    what phone are you using ?
    if you dial *32 , *33 , *34 what is happening ?
  5. aslampa
    Mar 18, 2016
    44
    It seems to be working when i re provision the phone
  6. andreasc
    May 19, 2014
    35
