How to change the voicemail extension number.
Discussion in '3CX Phone System - General' started by andykeen, Nov 12, 2011.
  1. andykeen
    Aug 12, 2010
    54
    Hi All.
    Hope this is a simple one!
    We have setup a new 3CX server with 8 extensions and the voicemail number is setup as 999.
    I wish to change this to something else.
    How can I do this please, can anyone please help.
    Thank you
    Regards
    Andy
  2. SnelleEdje
    Nov 6, 2011
    19
    In the 3CX management console select Settings->General->Voice Mail Menu Extension Number.
    Regards,
    Edwin
  3. andykeen
    Aug 12, 2010
    54
    Hi Edwin.
    Perfect - thank you very much for your help.
    Best Regards
    Andy Keen
  4. Jamie Bennett
    Dec 18, 2016
    9
    What happens if different phones have different extensions inside the phone? I.E the 7970 defaults the voicemail extension to 666, whereas the 7960 has it set to 999.
  5. leejor
    10,754
    286
    Once you have changed the VM number in the PBX, you'd have to have all sets affected, download a new configuration file, which should reflect the change. If a device was manually configured, you'll have to log into the device to change the VM access number.
