How to change Webmeeting FQDN
Discussion in '3CX Phone System - General' started by decalabs, Sep 21, 2016.
  1. decalabs
    Sep 21, 2016
    15
    while upgrading our 3CX installation from V14 to V15, we had to provide an FQDN for the PBX, so we chose pbx.companyname.tld as set in the previous V14.
    After the upgrade, we discovered that the Webmeeting FQDN was automatically set to pbxcompanyname.3cx.net. How can we change that to just companyname.3cx.net?
    Any help would be greatly appreciated.
    Dino
  2. decalabs
    Sep 21, 2016
    15
    Over four months later.... nobody?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,408
    282
    Your webmeeting FQDN is generated automatically based on the FQDN you choose to install the system.
    https://www.3cx.com/docs/fqdn-management-allocation/
    So in effect to change your webmeeting FQDN you need to change the FQDN you used to install the system
