How to check if my 3cx system has internet ?!!
Discussion in '3CX Phone System - General' started by ahmedsza, Feb 16, 2017.
  1. ahmedsza
    Jan 4, 2015
    17
    Dears
    I would like to ask is there any way to check from 3cx system GUI if there is internet in my 3cx system ?!,
    to apply the license and dont now if there is internet in my 3CX system.
    10,587
    253
    You won't be able to apply the licence if it can't connect.
    If you have any VoIP trunks, they will won't show as registered if there is no connection.
    You should be able to log into the system from another PC if it is connected to the LAN. You should be able to determine if the LAN has an internet connection using the computer you logged in with.
    If this is a Windows system, you could use a number of other programmes, on the 3CX server, to see if you have a connection.
    There is nothing that turns green to indicate an internet connection.
