How to check the default time zone of 3CX phone system V15
Discussion in '3CX Phone System - General' started by aslampa, Dec 11, 2016.
  1. aslampa
    Mar 18, 2016
    44
    My IP phones are showing wrong time, I think something wrong with default time zone. How to check the default time zone of 3CX phone system V15
  2. ALuisPV
    Mar 7, 2016
    28
    Hi ,
    in 3CX management console, go to Settings --> Parameters and search this string: "timezone"
    You can view all the default time zones for all the models and the default global time zone. Be careful and don't touch anything in this section if you are not sure.
    Anyway, you can configure a concrete time zone for each extension in "Phone Provisioning".
    Best Regards.
  3. aslampa
    Mar 18, 2016
    44
    I am using Grand Stream GXP 1610 and 1620 IP phones. These phones are provisioned but not taking the timezone which I selected at provisioning tab....It have setting for Auto. Please advice what I suppose to do
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Which templates did you use to provision these phones?
  5. aslampa
    Mar 18, 2016
    44
    Grandstream GXP 1160/1165
  6. ALuisPV
    Mar 7, 2016
    28
    Hi aslampa ,
    Can you check in the configuration file generated, what is the value of the parameter that defines the Time Zone for the GXP ?. You can view it with a text editor. The parameter is P64
    Best Regards.
  7. aslampa
    Mar 18, 2016
    44
    %%param::time_timezone_grandstreamexec%%
  8. YiannisH_3CX
    May 10, 2016
    6,016
    421
    If you have upgraded to SP4 you can navigate to settings>> timezone, office hours & holidays and check the time zone you have set from there.
