How to clear the IPBlacklist fastly in Version 14.0
Discussion in '3CX Phone System - General' started by martin Fournier, Dec 27, 2017.
  1. martin Fournier
    Dec 27, 2017
    7
    We have an very huge IPblacklist list and we want to clear it, cause it's to slow to manage and too huge. The system let us delete entries one by one only and it took 20 sec to delete one.
    How to clear all the list without taking days to do it?
    10,743
    281
    I find that deletes take a lot less time than that...something else is going on. Generally, people don't delete entries or they risk that IP trying again. I whittle them down by looking for IP's that i can combine by putting into a range.
  3. martin Fournier
    Dec 27, 2017
    7
    then I can blacklist the domain again. OK but we also got Ip blacklist from the internal IP range that is already whitelisted. May I get double entries for the same IPs?
  4. leejor
    10,743
    281
    They are listed numerically, pretty easy to scroll through and see any multiple entries.
  5. martin Fournier
    Dec 27, 2017
    7
    What I mean, is that I had do an IP range whitelist of the voice VLAN and 30 min later found the ip of one our phone in the blacklist. Same range that was whitelisted before. So this is why I want to clear thoses entries to eased the security process
  6. leejor
    10,743
    281
    Haven't seen that happen before, if implemented properly. I had a similar issue with ATAs being blacklisted. I simply put in the entire 192.168.0.0 with a subnet of 255.255.0.0 and never had an issue again.
  7. martin Fournier
    Dec 27, 2017
    7
    The system is been attacked. Some of their authentification password had been modified. That's why my ip phones been blacklisted
  8. martin Fournier
    Dec 27, 2017
    7
    We modify the firewall setting to not allow the earth acces to the PBX. It's must be better now.
  9. martin Fournier
    Dec 27, 2017
    7
    As for the blacklist, I try to whitelist an IP range, that was in the blacklist, but those entries doesn't disappeared from the deny list
  10. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Smoke a joiint and take your time undoing the mess. Either that or you need to modify the database.
  11. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    I would recommend upgrading to V15.5 since V14 is no longer supported. V15.5 is more secure and the user interface is a lot faster. You can also multi-select entries and delete them all at the same time.
  12. martin Fournier
    Dec 27, 2017
    7
    Thank you, but we need to ask our customer first, their refused the upgrade in october. Thanks for your reply.
