how to collect the call queue name
Discussion in '3CX Phone System - General' started by mr_dupond, Oct 5, 2010.
  1. mr_dupond
    Oct 5, 2010
    I wonder if it's possible to have the call queue name of each caller with 3CX Assistant.
    Thank you in advance.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Yes.
    You have to turn it on in the General Settings and then say whether you want to append or prepend to the caller id.
