how to config 3cx tunnel listening on multi IP.
Discussion in '3CX Phone System - General' started by kingwilliam, Oct 21, 2012.
  1. kingwilliam
    Oct 25, 2011
    my server have 2 network, one is 192.168.0.1/24 gw 192.168.0.254 (default), another is 192.168.1.1/24 gw 192.168.1.254. both are connected to internet.
    at 3cx v11 sp1, 3cx tunnel still only bind on 1 IP (selectable).
    may i have solution can bind multiple IP on 3cx tunnel?
    thank you!
    william
    10,356
    224
    Set the subnet mask on your gateways and device(s) to 255.255.0.0 and they will be able to communicate with each other. If you make use of outside (VoIP provider), you still have to be sure that providers see the correct public IP. Both Gateways can forward the 3CX ports to it's correct local IP.
    The 3CX server will have only one IP.
