how to configur DID Inbound Rules?
Discussion in '3CX Phone System - General' started by vsefcik, Feb 17, 2010.
  1. vsefcik
    Nov 18, 2009
    19
    I'm running 3CX version 8.0.10116 and can't figure out how to get the PSTN gateway Inbound Rules to work correctly. I'm using a DIalogic DMG2000 gateway, which processes calls in from and out to our PBX with no problems, as long as the call coming in is to a registered VoIP phone and the call going out is from a registered VoIP phone. I now want to configure some DID Inbound Rules to route calls to extension numbers that are not on registered VoIP phones to a phone that is registered. For example, I have extension 7070 configured in 3CX and it is on an Aastra phone, and the phone has registered. Calls to and from 7070 and the PSTN gateway work fine. I want a call to extension 7072 from the PSTN gateway to be routed to the phone with extension 7070. So I added a DID Inbound Rule that says DID/DDI number/mask is 7072 and Connect to Extension 7070. When I dial 7072 on the PBX, the SIP Invite gets to 3CX, which responds with "407 Proxy Authentication Required" and the Server Activity Log contains the following:
    09:46:48.603 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:7072@169.231.192.10;user=phone SIP/2.0
    Via: SIP/2.0/UDP 169.231.192.12:5060;branch=z9hG4bK801E438076C8097F2D084BF9A3D0261B
    Max-Forwards: 70
    Contact: <sip:7072@169.231.192.12:5060>
    To: <sip:7072@169.231.192.10;user=phone>
    From: <sip:4182@169.231.192.12:5060;user=phone>;tag=7C68324631353641000085EE;vnd.pimg.port=1
    Call-ID: 01B22719EE81400000000010@dialogic2.commserv.ucsb.edu
    CSeq: 1 INVITE
    Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, COMET, PRACK, REFER, SUBSCRIBE, NOTIFY, MESSAGE
    Supported: replaces, early-session, 100rel
    User-Agent: PBX-IP Media Gateway
    Content-Length: 0
    Diversion: <tel:8937072>;reason=unconditional
    If I configure extension 7072 in 3CX, but do not add this extension to a real VoIP phone, a call to 7072 restuls in a SIP "480 Temporarily Unavailable" (because it hasn't registered) and the Server Activity Log shows:
    09:55:10.755 [CM503008]: Call(25): Call is terminated
    09:55:10.725 [CM503020]: Normal call termination. Reason: Not available
    09:55:10.725 [CM503016]: Call(25): Attempt to reach <sip:7072@169.231.192.10;user=phone> failed. Reason: Not Registered
    09:55:10.725 [CM503017]: Call(25): Target is not registered: Ext:Ext.7072
    09:55:10.725 [CM503010]: Making route(s) to <sip:7072@169.231.192.10;user=phone>
    09:55:10.725 [MS210000] C:25.1:Offer received. RTP connection: 169.231.192.12:49038(49039)
    09:55:10.725 Remote SDP is set for legC:25.1
    09:55:10.715 [CM505001]: Ext.4182: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [PBX-IP Media Gateway] PBX contact: [sip:4182@169.231.192.10:5060]
    09:55:10.715 [CM503001]: Call(25): Incoming call from Sip.4182 to <sip:7072@169.231.192.10;user=phone>
    09:55:10.705 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 169.231.192.12:5060;branch=z9hG4bKD2D44D48D11F5E56207E3EC81AB4799D
    Max-Forwards: 70
    From: <sip:4182@169.231.192.12:5060;user=phone>;tag=61793246313536410000998D;vnd.pimg.port=1
    Call-ID: 01B2271BE481400000000012@dialogic2.commserv.ucsb.edu
    CSeq: 1 INVITE
    Content-Length: 0
    So, my question is: can I have a call from a PSTN gateway be re-routed to a registered extension if the called number does not appear on a real VoIP phone that has Registered? Thanks for any guidance.
