How to configurate 3CX for VOIP provider "BroadVoice
Discussion in '3CX Phone System - General' started by lateralis_m, Jan 2, 2008.
  1. lateralis_m
    Oct 10, 2007
    41
    Does anyone have configuration Instructions for Voip Provider broadvoice?
    I need to configure the VOIP provider details in 3CX and the I need to configure a Polycom SoundPoint IP 550 phone and Cisco 7960G phone.
    Please advise?
    Norm
  2. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    The Broadvoice template that comes with v5 worked for me out of the box. Some folks are having issues with STUN server and their firewall settings.
    Have you installed your broadvoice using the supplied template? Did you get some errors?
    No experience with Polycom, sorry.
  3. lateralis_m
    Oct 10, 2007
    41
    Thanks for your reply.....
    Yea.....I tried the template provided by 3CX...That didn't work...I have left the Stuns server setting blank, however, I have a feeling these are the issue...not sure what to configure for the STUNS server settings...
  4. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Try putting in the IP address in the Registration settings for Broadvoice
    Liens >> Manage Lines >> Manage Providers & Gateways >> Broadvoice >> Registration settings
    'Which IP to use in 'Contact' field for registration:'
    Specified IP: 147.135.12.221:5060
    Let me know if that helped.
  5. lateralis_m
    Oct 10, 2007
    41
    I tried it where you'd recommended...didn't work.....
  6. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Could you post some of the debug log from your 3CX server where it shows trying to register the Broadvoice. Maybe something will stick out.
    Are you on a Nat'ed server?
  7. Jfetty
    Jan 5, 2008
    same problem
    I am having what I belive to be the same problem with broadvoice. I can not make outgoing calls. Here is my server log.
    17:31:41.309 Call::Terminate [CM503008]: Call(3): Call is terminated
    17:31:41.259 Call::RouteFailed [CM503014]: Call(3): Attempt to reach [sip:015862580000@10.2.41.22] failed. Reason: Reason Unknown
    17:31:41.249 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:15862580000@sip.broadvoice.com has failed; Cause: 400 Bad Request; from IP:147.135.12.221
    17:31:40.759 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(3): Calling: VoIPline:10000@[Dev:sip:5862580000@sip.broadvoice.com:5060]
    17:31:40.558 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.101 to [sip:015862580000@10.2.41.22]
