How to configurate 3CX for VOIP provider "Telphin"
Discussion in '3CX Phone System - General' started by rolf, May 6, 2007.
  1. rolf
    May 6, 2007
    13
    :?: Can you help me to configurate 3CX for VOIP provaider "Telphin".
    It is russian provider of ip-telephony. I tried to configurate 3CX according to the instruction, but it doesn't help. Provider's website: http://www.telphin.com , http://www.telphin.ru
    I shall look to hearing forward very much!
    Good luck!
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Well need to know what IP phone you are using, what exactly does not work and the server status log..
  3. ligo
    Aug 8, 2007
    Adjustments for provider Telphin by means of which it is possible to call and accept entering calls:
    Registrar/Proxy Hostname or IP: sip.telphin.com port: 5068
    Outbound Proxy Hostname or IP: voice.telphin.com port: 5068
    STUN server Hostname or IP: [blank] port: 10000
    Time between registration attempts (in seconds): 1800
    Require (optionally: authorized) registration for: Both in-out calls
    Which IP to use in 'Contact' field for registration: Both (external and internal)
    Codecs: G.711 A-law & G.711 U-law
    Supports Re-Invite: off
    'To.user' field: on
    'Request-Line-URI' field: on
    'RemotePartyID;party=called' field: off
    Use IP in 'Contact' to recognize source: off
    (Other adjustments to leave by default as were at creation of the VOIP-channel)
  4. ligo
    Aug 8, 2007
    additional remarks
    The provider supports codec GSM and, probably, Speex is it is possible to coordinate in their support service. That it was possible to call by means of 3CX PBX it is necessary to be connected under plans http://www.tel-me.ru
  5. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hello
    I am not sure exactly what the problem is. Is it registering or not?
    Can you explain what it is that is not working exactly so I can help?
