How to configure aastra phone working from remote site
Discussion in 'Windows' started by deepakparmar, Aug 14, 2010.
  1. deepakparmar
    Aug 8, 2010
    5
    Hi all,
    If anyone used aastra phone connecting to 3CX from remote end via WAN.
    I am able to use 3CX softphone from remote site, just failed to make it work aastra phone.
    If anyone done this type of configuration then guide me or give me suggestion.
    Cheers
    Deepak
  2. mcgaryt
    Aug 27, 2009
    20
    What are the symptons of "not working".
    Not registering? One way audio?
  3. leejor
    10,767
    286
    Unless you are using the 3CX tunnel option you pretty much have to use STUN if the remote set is behind a router. Be sure you have that set up and working.
