Here is the log file
14:59:42.265 [CM503020]: Normal call termination. Reason: Not found
14:59:42.265 [CM503016]: Call(40): Attempt to reach <sip:
[email protected]:5060> failed. Reason: Not Found
14:59:42.265 [CM503014]: Call(40): No known route to target: <sip:
14:59:42.250 [MS210000] C:40.1:Offer received. RTP connection: 192.168.1.29:10112(10113)
14:59:42.250 [CM503010]: Making route(s) to <sip:
14:59:42.250 Remote SDP is set for legC:40.1
14:59:42.234 [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13527.0] PBX contact: [sip:
[email protected]:5060]
14:59:42.234 [CM503001]: Call(40): Incoming call from Ext.105 to <sip:
14:59:42.140 [CM500002]: Info on incoming INVITE:
INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.29:5080;branch=z9hG4bK-d8754z-112eeb7a4f7bf050-2---d8754z-;rport=5080;received=1111.111.111.111
Via: SIP/2.0/UDP 116.71.38.187:10005;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport
Via: SIP/2.0/UDP 127.0.0.1:4316;branch=z9hG4bK-d8754z-112eeb7a4f7bf050-1---d8754z-;rport=4316
Max-Forwards: 68
Record-Route: <sip:
[email protected]:5080;user=proxy;uri="116.71.38.187:10005">
Contact: <sip:
[email protected]:4316;rinstance=6f5ba40617cfbe81>
To: <sip:
[email protected]:5060>;tag=196b847a
Call-ID: YzE4NDM4Y2QxYjdkMDAwMjllZmM4YTU3ZGQ2NTg1MzY.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="105",realm="3CXPhoneSystem",nonce="414d535c026b54cc91:967549621cae735eba09788ae725cc7c",uri="sip:
[email protected]:5060",response="5fb0ef9f9fd433813e1cb211a7dade70",algorithm=MD5
Supported: replaces
User-Agent: 3CXPhone 4.0.13527.0
Content-Length: 0
14:59:23.359 Currently active calls [none]
14:58:53.343 Currently active calls [none]
14:58:23.312 Currently active calls [none]
14:58:00.375 [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:
[email protected]:4316;rinstance=6f5ba40617cfbe81/105]
3CX Located on Network A, I am at Network B and my friend at Network C. We are connecting with the server from different countries and server located in another country.
Sometimes I and my friend connect without any problem and we can talk to each other but sometimes system work in half duplex mode. We don't have any problem with the firewall.
I am using net2phone for outbound calls. Using sip.net2phone.com and my ID and Password and Ports/Trunks Status showing me green light in 3CX but when I try to call 90044791266648 or 004479126664 then 3CX softphone giving me Forbidden and Destination Not Found error.
Please find attachment with this post.
