- Joined
- Sep 1, 2007
- Messages
- 25
- Reaction score
- 0
These options basically can be set to "enable" or "disable"
As a newbie I'd like to know what it's about. and how to set this in version 3.1.2434, my phone system doesn't seems to work very well and sometimes it can't register in the 3cx system and some times it work.
I wonder if any configuration I should set to cater for 3cx
A: sip extension
1.Support PRACK method with provisional response reliability
2.Encode SIP URI with user parameter
3.Session Timer use UPDATE method
4.enable Global Number support(E.164)
5.enable Call Hold using c=0.0.0.0 (RFC 2543) in SDP (disable RFC3263)
6.send NOTIFY for REFER request
B: Supplementary Service Subscription
1. Enable Caller ID
2....
C: OOB Signaling
1.RTP Telephone Event Configuration
Send DTMF Events Options:
out-of-band(RFC2833) (default)
in-band
in-band &OOB
Info(RFC2976)
Regenerate OOB DTMF tone (yes or no)
A: sip extension
1. Enable Caller ID
2....
C: OOB Signaling
in-band
in-band &OOB
Info(RFC2976)
