How to configure VOIP client for offsite use.
Discussion in 'Windows' started by mutti_wilson, May 2, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    What is the easiest way to configure the client to work offsite? I have the ports that are recommended to opened up in the router. I am using build 4492. I'm new to this IP-PBX, but I think it's awesome so far and having fun jumping into it and getting it up and running for our business. Thanks for the help.
  2. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    #2 demonofsteel, May 3, 2008
