Solved How to configure Yealink EXP40 in 3CX web panel
Discussion in '3CX Phone System - General' started by Matt Stephens, Mar 9, 2018.
  1. Matt Stephens
    Mar 8, 2018
    41
    I'm having the same issue as this post here
    https://www.3cx.com/community/threads/yealink-exp40-dss-keys-clearing-on-power-loss.41757/
    We have Yealink T46S Phones, two of them have the EXT40 expansion module. I can configure the expansion module buttons via the phone's web interface, but every time it sends a provision request to the server those buttons get wiped out. It's a real pain to reconfigure every time.
    My question is, how do I configure the expansion module in the 3CX panel instead of the phone web page? Adding BLF buttons just give extra pages on the phone LCD, I can't find a way to configure the exp40 itself
  2. Matt Stephens
    Mar 8, 2018
    41
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    Looking in the template... Are you starting with the right BLF Key?
    {IF ua=SIP-T46G,SIP-T46S}
    #Expansion module1 key1
    {IF blf28}
    expansion_module.1.key.1.type = %%DKtype%%
    expansion_module.1.key.1.line = %%Line%%
    expansion_module.1.key.1.value = %%type%%
    expansion_module.1.key.1.pickup_value = %%PickupValue%%
    expansion_module.1.key.1.label = %%label%%
    expansion_module.1.key.1.extension = %%PickupValue%%
    expansion_module.1.key.1.xml_phonebook =
    {ELSE}
    expansion_module.1.key.1.type = 0
    {ENDIF}
  4. Matt Stephens
    Mar 8, 2018
    41
    Thanks Craig, I'm pretty sure that is my problem - going to try it out now.
  5. craigreilly
    Feb 1, 2012
    3,321
    253
    Better off going with the correct BLF number listed here than changing the template in my opinion.
  6. Matt Stephens
    Mar 8, 2018
    41
    Yep, just start configuring BLFs at number 28, leaving the rest blank. Works like a charm
    craigreilly likes this.
  7. craigreilly
    Feb 1, 2012
    3,321
    253
    Now if they would add a "Add 5 BLF's" or "Add 10 BLF's" then it would make it easier... and a "COPY BLF FROM EXT" to make it easier. :)
  8. Matt Stephens
    Mar 8, 2018
    41
    Yes, that would be great
    Even import a text file would make it much easier.
    to have to click dropdown, BLF, dropdown, Extension#, 40 times is quite tedious.
    However, it is much easier than the phone webpage itself, and now I know I won't ever have to do it all over again (this was at least the 4th time for each phone).
