How to connect 3CX PBX to Cisco router gateway by IP-to-IP
Discussion in '3CX Phone System - General' started by datagem, Aug 14, 2013.
  1. datagem
    Nov 7, 2011
    Dear All.
    has anyone tried connecting 3cx directly to cisco router using the router as a voip gateway. i have tried from the link http://www.3cx.com/forums/how-to-connect-3cx-pbx-to-cisco-router-gateway-by-ip-to-ip-1487.html but 3cx did not register the gateway.
    any help will be appreciated. Thanks
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Re: How to connect 3CX PBX to Cisco router gateway by IP-to-
    How about a little more info like router model and version of 3CX?
  3. datagem
    Nov 7, 2011
    the router model is AS5850 with the following information:
    1. IOS image "disk0:c5850tb-p9-mz.124-13b.bin"
    2 . Cisco IOS Software, 5850tb Software (C5850TB-P9-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
    3. the version of the 3cx is version 11
    thank you for your concern.
  4. lneblett
    Sep 7, 2010
    2,088
    65
    Now then, what are you actually trying to do with the device. It has quite a bit of capability, but this also depends on what optional cards and features you are trying to use.
