how to connect a pots line to 3cx as an extension
Discussion in '3CX Phone System - General' started by Shawn, Jan 19, 2018.
Tags:
  1. Shawn
    Feb 2, 2017
    95
    our 3cx connects to a sip trunk and inbound calls are routed through this trunk. my current failover configuration routes inbound calls to cell phones if the sip connection goes down.
    i'd like to get one or two pots lines and have the calls routed to the pots lines instead during sip outages. ideally, these pots lines would sit as extensions on 3cx that would ring when inbound calls are routed to them during an outage. i guess i'm looking for a device that will function the opposite of the weltech ata 172 where this thing creates an analogue dial tone from a digital extension on the pbx and i'm looking to create a digital extension on the pbx from an analogue dial tone as provided by a pots line provider.
    any ideas or suggestions to accomplish an alternate route for inbound calls would be great.
    thanks
    shawn
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    900
    137
    Hi Shawn,
    Most definitely the Patton 411x JO (FXO) series model gateway. Very good solid product that will connect 2/4/6/8 Analogue lines to your system (you would want the 4112 JO model).
    https://www.patton.com/voip-gateway/sn4110/
    This model is full supported by 3CX for auto-configuration from the PBX also. The other alternative is beroNet which is also supported for auto-configuration.
    https://www.3cx.com/voip-gateways/patton-smartnode-sn4112/
    https://www.beronet.com/products/voip-gateways/analog-gateway/beronet-4-fxo-voip-gateway/
