How to connect Analog phones with 3cx
Discussion in 'Windows' started by manistopit, Feb 18, 2009.
  1. manistopit
    Feb 18, 2009
    26
    Hi There
    First of all thank you everyone who give there valueable suggestions on this forum and help me so many time when ever i faced technical problem .thank you again
    This is first time im writing in this forum
    We are using licenced version of 3CX since 2007 and very happy with them.
    At present we are using soft phones of eye beam in our office but there is so much voice cracking and so many other problems we are facing with soft phones
    We planing to shift to Hard Analog phone with help of Voip gateway.
    """""""""""We are using VOIP lines only NO PSTN line """""""""""
    As per my research i found out that the best one is Audiocode Mp118 which suite to our small office and also with in budget as well
    But im bit confuse with the FXO and FXS
    There are two type of Audiocode Mp118 availiable in the market one is FXO and other is FXS
    ... So my question is which one shall i purchase FXO or FXS
    And can u recomend any good Analog phones for small back office purpose with which we can connect headsets
  2. manistopit
    Feb 18, 2009
    26
    Today i called audiocodes guy he said i require FXS Audicodes not FXO ..
    In the Audiocodes they got there internal login page where we can add 3cx extenstion numbers to each port...
    We are only using VOIP
    But the link you given me it refering for FXO
    Pease help
  3. manistopit
    Feb 18, 2009
    26
    Thank you matt that is helpfull :p :p :p :p :p :p
    You solved my problem
