How to connect outside of LAN ?
Discussion in '3CX Phone System - General' started by vand, Jun 16, 2014.
  1. vand
    Oct 18, 2013
    8
    Hi All
    I have some problem with connection, I able to make and receive call in LAN I can dial out externally however if I need to use my phone over 3G network just cant register.
    Firewall has been checked, I'm using public IP without STUN also extensions have full permission I can figure out what could be wrong?
  2. Shark8000
    Jun 15, 2014
    9
    Have you tried using the tunnel???
  3. vand
    Oct 18, 2013
    8
    yes I tried with tunnel no connection...
  4. Shark8000
    Jun 15, 2014
    9
    Check port forwarding rules in your firewall
  5. vand
    Oct 18, 2013
    8
    all open already I will try to restart 3cx out of office hours maybe that will help...
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    who is your mobile phone provider? in what country?
  7. leejor
    10,357
    224
    It may very well be a 3G issue, but have you confirmed?
    Have you tried using wifi from outside the locate LAN? Does the 3CX log show any registration attempt, even a rejection?
  8. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Make sure the extension is set to allow registrations remotely. It is disabled by default I believe. We have a crummy version of 4g LTE here and we cant use it for 3cx remote phones because of call quality issues. Hope you have better luck on your 3g.
  9. vand
    Oct 18, 2013
    8
    I reboot the 3cx server all back to normal. Thanks for help!
