How to connect over the internet
Discussion in 'iOS' started by EKrediet, Dec 29, 2010.
  1. EKrediet
    Apr 28, 2009
    5
    The 3cx-Iphone app works fine over my Wifi connection at the office and at home.
    But i should be able to get a connection when outside, shoud i not? on 3G...
    I opend port 5060 but still.... what am i missing?
    Eric
  2. r2k
    r2k
    Jan 9, 2011
    23
    Hi Eric,
    i dont' have a solution for this problem, but I have the same problem.
    I've open TCP 5060 from the internet to the pbx and i am able to register. But when i try to call my voicebox, it does not connect. When I check the extension status, my iphone is "on line".
    I've connected my iphone 3g by wifi from my home place. Firmware ist 4.2.1.
    I think there are some additional ports (which i did not find in the manual)
    Best regards
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    @Eric
    Are you using the 3CX-iPhone as a standalone device or did you configure it as an external extension.
    To keep in mind: A lot of mobile phone providers block port 5060 in there network to prevent people can make free calls over there network instead of paid calls.
    @r2k
    You must open port 5060 TCP and UDP for the internet.
  4. r2k
    r2k
    Jan 9, 2011
    23
    Thanks for your answer. I've open now TCP and UDP 5060, still no way :(
    Are there other ports needed for the iPhone app? (btw: is there a manual?)
    Here is something out of the log:
    20:33:36.877 [CM502001]: Source info: From: <sip:224@pbx.mycompany.ch>;tag=q.Jj7Ws1lAXYLqGXCXcKHFuB8RQJSvaD<sip:999@pbx.mycompany.ch>
    20:33:36.877 [CM503013]: Call(25): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 999 @pbx.mycompany.ch tid=Pj5MyymYnUPXatnAs2SkYL9DcnugIYtk2M cseq=INVITE contact =224 @83.76.185.223:22786 / 30427 from(wire)
    20:33:36.537 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:999@pbx.mycompany.ch SIP/2.0
    Via: SIP/2.0/UDP 83.76.185.223:22786;rport=22786;branch=z9hG4bKPjDUm3Emi4VRnBnGSeDSpNoFseJnz0Kah0
    Max-Forwards: 70
    Contact: <sip:224@83.76.185.223:22786>
    To: <sip:999@pbx.mycompany.ch>
    Call-ID: PM.XSq-luRZL.jOQTlle3B.r7fvqacC1
    CSeq: 30426 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Supported: replaces, 100rel, timer, norefersub
    User-Agent: 3CXPhone for iPhone 1.0.19
    Content-Length: 0
    20:33:36.536 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 999 @pbx.mycompany.ch tid=PjDUm3Emi4VRnBnGSeDSpNoFseJnz0Kah0 cseq=INVITE contact=224 @83.76.185.223:22786 / 30426 from(wire)
    20:31:17.190 Exception thrown from Transportprocess: ParseException .\ParseBuffer.cxx:79, Parse failed skipped over eof in context:
    @ .\ParseBuffer.cxx:79
    20:31:16.936 Exception thrown from Transportprocess: ParseException .\ParseBuffer.cxx:79, Parse failed skipped over eof in context:
    20:31:16.683 Exception thrown from Transportprocess: ParseException .\ParseBuffer.cxx:79, Parse failed skipped over eof in context:
    20:31:15.511 Exception thrown from Transportprocess: ParseException .\ParseBuffer.cxx:79, Parse failed skipped over eof in context:
    *****exit
    20:31:13.961 Exception thrown from Transportprocess: ParseException .\ParseBuffer.cxx:79, Parse failed skipped over eof in context:
    *****quit
  5. complex1
    Jan 25, 2010
    752
    38
    Please read this topic
    http://www.3cx.com/forums/overview-of-3cxphone-for-the-iphone-18586.html
  6. r2k
    r2k
    Jan 9, 2011
    23
    thanks!
    i found out my mistake: I had the wrong sip domain :) now it works :)
