How to connect Predictive dialer with 3CX
Discussion in '3CX Phone System - General' started by manistopit, May 19, 2009.
  1. manistopit
    Feb 18, 2009
    26
    Need help
    is that possible if yes which dialers we can use
    Thank you in anticipation
    10,744
    281
    I assume that it is an analogue device designed to be use on a POTS line. In this case you would have to use it with an ATA (analogue telephone adapter), which would give you dialtone and allows a standard phone to be used with a VoIP system.
  3. manistopit
    Feb 18, 2009
    26
    Anybody
  4. leejor
    10,744
    281
    With an ATA adapter you can use ANY dialer that you would use with a regular POTS telephone line.
  5. mbaltus
    Dec 12, 2008
    66
    If you are looking for an actual predictive dialer, then through the API you currently won't succeed. My guess is that you have the most success with a SIP based predictive dialer. Running that through google should give you a lot of hits. Sorry to say that I don't have any experience with them.
  6. manistopit
    Feb 18, 2009
    26
    @above can you suggest any predictive dialer with 3CX
  7. manistopit
    Feb 18, 2009
    26
    @leejor
    Mate this is not about Analog phones Im asking about Dialers in call center
    Anyway thank you for trying
  8. mbaltus
    Dec 12, 2008
    66
    like I said, I don't have any experience with SIP based dialers, so I cannot advice any further.
  9. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    http://www.nch.com.au/ivm/index.html
