How to create CSR?
Discussion in '3CX Phone System - General' started by fonewiz, Mar 8, 2016.
  1. fonewiz
    May 13, 2015
    44
    I have created many CSR request, ordered certs and installed them on both IIS/Windows and Apache/Linux.
    This is the first time I am ordering/installing an SSL cert for 3CX v14 use.
    First install of Version 14 Virtual PBX version.
    While installing 3CX, I get to the option where it ask me if I want to import a cert or generate a self signed cert.
    I do NOT want to use a self signed cert but I don't yet have one to import. I would like to order a cert but in order to do that I normally need a CSR. There is not option to create a CSR at install time so??
    How should I create the CSR for 3CX use?
    If I use a self signed for now, can I change to the cert I purchase later or will I have to do the whole install over?
    Since we use Yealink phones, I will need to purchase a MUCH more expensive wild card cert from a more expensive Cert Authority because Yealink phones only allow by default a few Cert Authorities. Because this will be an expensive cert, I want to be sure I order it correctly and hopefully it can also be used for SIP TLS when I set that up later. I have read that the TLS cert needs to be a separate cert but, I am not sure about that right now, need to research further.
    Thanks in advance for any assistance with these issues.
  2. fonewiz
    May 13, 2015
    44
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
  4. fonewiz
    May 13, 2015
    44
    I have a ticket in with 888VoIP right now.
    There are no specific steps really so there is a lot of room for error and wild card certs are expensive.
    I went ahead with the 3CX install and used a self signed cert generated by the installer. I think I can now go into IIS and generate a new CSR, order the wild-card cert and install it which will replace the self signed cert.
    At this point, I think 3CX should be happy as the process seems to be mostly outside of 3CX as far as I can tell.
    Mostly assumptions at this point but, I am going to move forward with these assumptions unless I get better info before I pull the trigger and order my cert.
    To make the cert even more expensive, I can only order certs from Trusted Authorities that Yealink trust in their phones if I want Auto-Provisioning to work correctly. ***Sigh*** ***Deep Breath***
  5. craigreilly
    Feb 1, 2012
    3,575
    305
    the v11 SSL was similar in process to what you explained.
