How to create IVR menu options via API Call Control?
Discussion in 'CRM / Helpdesk / App Integration' started by itsystem, Dec 11, 2012.
  1. itsystem
    Jan 25, 2011
    15
    Hello!
    Could you help me please!!!
    I need develop dynamic application which will be integration with my software. My application must read SQL-query and then create IVR with different menu options.
    I learned 3CX API CAll Controll and not found how to create IVR menu Options with help of it.
    I try using that code:
    Code:
     DN dn0 = PhoneSystem.Root.GetDNByNumber("101");
    IVRForward fw0 ;
    fw0.ForwardType = IVRForwardType.Extension;
    fw0.ForwardDN = dn0;
    ivradd.Forwards[0] = fw0;
    But it don't working...
    Help please...
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    This is not related to the Voice Application Designer. You should ask this question in the general forum.
    The documentation of the API you're using is here:
    http://www.3cx.com/blog/docs/call-control-api/
    There you have a ZIP file for download, which contains some code samples, but pretty sure you already have it. There is no support for that API, you will have to use it on your own.
    Regards,
  3. itsystem
    Jan 25, 2011
    15
    Thank You!
    I learned this manual and samples but didn't find answer.
    I repost question on General Forum.
