How to create IVR menu options via API Call Control?
Discussion in '3CX Phone System - General' started by itsystem, Dec 12, 2012.
  1. itsystem
    Jan 25, 2011
    15
    Hello!
    Could you help me please!!!
    I need develop dynamic application which will be integration with my software. My application must read SQL-query and then create IVR with different menu options.
    I learned 3CX API CAll Controll and not found how to create IVR menu Options with help of it.
    I try using that code:
    Code:
    DN dn0 = PhoneSystem.Root.GetDNByNumber("101");
                IVR ivradd = PhoneSystem.Root.GetTenants()[0].CreateIVR("886");
                ivradd.Name = "TestIVR";
                ivradd.PromptFilename = "prompt.wav";
                ivradd.Timeout = 20;
                IVRForward fw0 ;
                fw0.ForwardType = IVRForwardType.Extension;
                fw0.ForwardDN = dn0;
                ivradd.Forwards[0] = fw0;
                ivradd.TimeoutForwardType = IVRForwardType.VoiceMail;
                ivradd.TimeoutForwardDN = PhoneSystem.Root.GetTenants()[0].GetExtensions()[0];
                ivradd.Save();
    But it don't working...
    Help please...
  2. Hardik Soni
    May 22, 2017
    19
    i have same issue
    i want same exactly..
    i can create IVR but i can't create IVR forward(IVR menu item)
    can anybody suggest how can i create IVR forward.
