How to create new entries into phone book?
Discussion in 'Windows' started by leslie80, Sep 16, 2011.
  1. leslie80
    Sep 16, 2011
    Hello to all,
    Just installed 3CXPhone and trying to figure out how it operates.
    If I am not missing something I can not see how could be created new entries into the phone book.
    Thank you.
  2. leslie80
    Sep 16, 2011
    OK I figured this out. But now how the entries can be removed.
    When entry is clicked on it starts calling. Doesn't remove entry via editing neither.
