how to create ring group in call control api
Discussion in 'CRM / Helpdesk / App Integration' started by VITS 3CX, Mar 15, 2018.
  1. VITS 3CX
    Mar 12, 2018
    17
    i am using the call control api so how to create the multicast paging group.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,150
    86
    Hello @VITS 3CX,
    You just need to create a Ring Group, and then set the strategy to "RingGroup.StrategyType.Paging".
    In order to create a Ring Group, just create a new instance of the class "RingGroup", set its properties and invoke "Save()" to create it.
    Kind regards.
  3. VITS 3CX
    Mar 12, 2018
    17
    how to C# Call Control API MakeCall and play audio
