How to delete all contacts in the phone book
Discussion in '3CX Phone System - General' started by voipi, May 11, 2017.
  1. voipi
    Oct 18, 2011
    Hi all,
    I try to delete all entries in the phonebook, but there ist no "Delete all" button in the list?
    Thanks for your help.
    Best wishs
    Oli
    P.S. I have seen that in the Beta 15.5 is the button available
  2. Divyesh
    Apr 21, 2017
    20
    You can hold Ctrl and click on each contact then click delete.
  3. voipi
    Oct 18, 2011
    Hi Divyesh,
    with 1400 contacts that sound not very funny. This can not be the solution ...
    Best
  4. leejor
    11,117
    329
  5. Taff3333
    Jan 18, 2017
    21
    6
    Have attached a tool gave to me from 3cx support.
    Will remove all contacts, would advise a backup before running this
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,422
    538
    Please perform a backup before using this tool. Also keep in mind that in version 15.5 a button has been added to delete all contacts and this tool will not be necessary.
