How to delete and re-add phones
Discussion in '3CX Phone System - General' started by thames, Dec 1, 2012.
  1. thames
    thames New Member
    Apr 4, 2011
    102
    Hi Folks
    I desperately need to delete two of the phones my system (version 11) is using so I can treat them as new phones and re-allocate them to existing extensions. Can anyone tell me how to make the 3cx system "forget" the mac addresses of the two phones in question so I can do this?
    Cheers
    Chris
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    if your phones are provisioned you can delete their files, path is this:
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\interface\provisioning
    or
    C:\ProgramData\3CX\Data\Http\interface\provisioning
  3. thames
    thames New Member
    Apr 4, 2011
    102
    Hi there
    Is it the .cfg files for each mac address I need to delete or, if not, which files exactly am I looking for?
    Cheers
    Chris
  4. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Delete the files which contains the mac address of the phone in file name (cfg)
  5. thames
    thames New Member
    Apr 4, 2011
    102
    Thanks very much! OK - have done that - will now try and reprovision.
    Cheers
    Chris
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    The most important question is, are you using option 66?
    If yes, turn it off, do a factory reset of the phones and make sure that you delete the MAC addresses from within the extensions previously used. Depending on the phones, they likely have 3CX plug n play and they will appear in bold in the phones section of 3CX From here simply assign them. This option will NOT work is option 66 is active, if so you will need to go and manually delete the provisioning files.
  7. thames
    thames New Member
    Apr 4, 2011
    102
    Sigma1 - thanks very much for your post. Sorted!
    Cheers
    Chris
