How to delete Call Log
Discussion in '3CX Phone System - General' started by glynco, Jul 14, 2007.
  1. glynco
    Jul 14, 2007
    20
    How can I delete the call logs?
  2. Anonymous
    Anonymous Guest
    Logs you meen the files or the database entries?
    You can configure the files in 3cxsystem.ini
  3. glynco
    Jul 14, 2007
    20
    The outgoing call log report
  4. Anonymous
    Anonymous Guest
    Can't unless you go into the database and to it there.
    Workaround:
    Backup database, excluding the call logs and reports.
    Uninstall 3cx
    Remove the installation dir
    Re-install 3CX
    Restore DB.
    Will give you a clean install, without the call logs.
  5. glynco
    Jul 14, 2007
    20
    Is there another way? Like SQL editor?
  6. Anonymous
    Anonymous Guest
    Sure, but I am not that brave :).
    The work arround is the fastest, and the safest.
