How to delete Skype Gateway ports?
Discussion in '3CX Phone System - General' started by mobidutch, Aug 26, 2010.
  1. mobidutch
    Feb 6, 2010
    26
    When I went through the installation wizard of the 3CX Skype Gateway, I told it to create 4 ports. I actually had 4 concurrent calls in mind, which you can specify in the settings for a port. So now I have 3 extra ports created that I don't need. I'm guessing they're not hurting anything, but is there a way to remove Skype Gateway ports from 3CX?
  2. TotallyVoIP
    Jul 2, 2010
    77
    Select the 3CX left hand menu "PSTN devices", then you will see the ports listed on the right hand side
    select the ones to delete and then in the menu above them select delete.
    good luck
